Orbi WiFi 7 RBE973
Reply
Orbi 5 to Orbi 6 Upgrade Question
VAEAGLE367
I will be upgrading my home network from Orbi 5 to an Orbi 6 (AX6000) network.  I have 42 wifi connections in my home.  Will I be able to "clone" the Orbi 5 network settings in my Orbi 6?  In other words, if I use the same network name and password, will it just connect to my devices as usual?  I really don't want to have to reset everything.  Also, since I already have the app on my phone, will I have to do anything with that?
Thanks!
Message 1 of 2
Guru
Re: Orbi 5 to Orbi 6 Upgrade Question
Yes you can use same SSID name and PW on Orbi AX.
Be sure visit the Orbi AX forum for your Orbi AX quesions, help and information:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 422 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
