- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi 50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi 50
Since a few weeks the Orbi router Restart itself without any notice. No logs etc. and took quite some time to connect to the satellite and this only in yellow. I have the actual firmware installed but this was probably the start of the problem. Are there suggestions how to solve it? Thanks for any help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 50
Please try a factory reset and setup from scratch with the RBR and RBS...
hat is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 50
I would move the RBS farther out. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
