Orbi WiFi 7 RBE973
Reply
Orbi 6to4 and 6rd IPv6 Issues
ddalbroi
Hi Guys,
I'm having a few interesting issues trying to configure either a 6to4 or 6rd IPv6 connection on my Orbi RBR40 router. The firmware version is V2.0.0.56.
When configuring a 6to4 or 6rd connection, I initially am able to establish a connection and my nework devices recieve IPv6 addresses and I am able to validate connectivity at http://ipv6-test.com/; However after a period I appear to loose connectivity; all devices still retain thier IPv6 addresses, they can ping and route to IPv6 internet hosts, however when trying to browse to a site there appears to be no IPv6 connectivity and http://ipv6-test.com/ shows that only IPv4 connectivity is able to be established.
The interesting thing is that if I disable and then re-enable the IPv6 connection on the router everything then works again, but only for a short time period.
Ive read that this is also an issue on other Netgear routers, that a beta firmware upgrade resolves.
Has anyone experienced this issue or can anyone offer any advice?
Cheers
Dean
Message 1 of 2
Kyne
Apprentice
Re: Orbi 6to4 and 6rd IPv6 Issues
I have a simialr issue with native dual-stack. This looks like it's a Netgear issue.
I am on native IPv6, but after 1-x days, none of my devices can route via IPv6 anymore, even though they retain the address. I need to refresh ("Apply" in the ipv6 pane on the Orbi to fix it - but it'll break again after a few days.
Netgear has the same bug in other routers...... 😞
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1746 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
