Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi AC 3000 RBK 53
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-24
03:14 AM
2020-09-24
03:14 AM
Orbi AC 3000 RBK 53
have current system which contain TP link router connected to network switch
and Cisco WAP 371 , 121 access points total 17 access points connected to the same network switch with TP link router
my question is
1 - if i replace current TP link router with orbi router does cisco access point it will keep working with orbi ?
2 - can i use both cisco access point and orbi satellite nodes with orbi router ?
3 - How many devices in the network can I block if I am using an orbi router with at least 25 devices? I want to block the internet at night ?
my question is
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-24
07:04 AM
2020-09-24
07:04 AM
Re: Orbi AC 3000 RBK 53
my question is
1. The Cisco access point should obtain an IP address and keep working. However it will not technically be part of the mesh system.
2. Yes, but read 1.
3. You should be able to block all device connected to the Orbi router. 25 is no problem.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-24
02:49 PM
2020-09-24
02:49 PM
Thanks for your support but I guess i will face problem because in case if iam connect my phone to orbi node while I moving to another floor the signal it will become weak so it will not connect directly to nearest Cisco access pointi have to disconnect from orbi and connect to Cisco .
So if I want use nighthawk router which model can fit my requirement specially blocking users or device's
Message 3 of 3
Announcements
