Reply
Orbi AC2200 won't connect to internet
RCamilleri
Follower
Hi there, I am hoping someone can help me. I just bought a Netgear Orbi AC2200 router and 2 satellites to strengthen my internet for my parents as they have just moved into our granny flat and they cannot pick up my internet.
However on initil set up I cannot connect it to the internet. I just rang the Netgear helpline as they say you get free support for 90 days, however on talking to them they said they will need to charge me $69 to talk to a Mac specialist to change some settings on my Apple computer to configure it.
Is this information available anywhere for me to do myself? I just spent $450 already on the system, and no where does it tell me that I will have to spend hours failing to connect and then eventually spend another $69 to fix it. I think thats madness! I was just wondering if anyone knows what settings need to be changed on a iMac to get it started.
Thanks so much in advance!
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi AC2200 won't connect to internet
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 786 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
