Orbi WiFi 7 RBE973
Reply
Orbi AC3000 RBK53S cable connection DOCSIS 3,1
4UToday
We ordered yesterday Orbi AC3000 RBK53S and today we found out we need to change our internet from satilite to cable.
The cable company (Comcast) said we need a modem that is on their approved list. Well, Orbi AC3000 RBK53S  is NOT but they do have CBR750 and other Netgear products.
How can we go forward with our purchase of Orbi AC3000 RBK53S?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 10
Accepted Solutions
Guru
Re: Orbi AC3000 RBK53S cable connection DOCSIS 3,1
If you already bought the RBK53s, and your changing to a cable ISP, find a cable modem that is approved on the cable ISPs approved list. You can buy one of these at online retailers. Or you can use an ISP provided modem, ask them about a stand alone modem only if they have one. Once you have a cable modem, you'll need to have the ISP associate the modem on there system. Something to contact them about.
Once it's online with the ISP, you can connect the Orbi RBR to the modem and setup the Orbi system for your needs. The RBK53s needs a modem or ONT connect too to get ISP and Internet services thru it.
@FURRYe38 wrote:
NGs CM1000, 1100 and 1200 modesm are D3.1 compliant as well. These are stand alone modems that work with Orbi systems.
Message 7 of 10
All Replies
Mstrbig
Master
I don't see a reason to have to change, if you have a router connected to the Satellite.
With that said, if you want DOCSIS 3.1, the Arris SB8200 and CM8200 are compatible. Netgear also makes DOCSIS 3.1 modems. Since you have the Orbi kit, I would stay with a modem only model like the SB8200 and not a modem/router combo.
Message 2 of 10
4UToday
Satilite is ethernet to a aircube and Comcast said we would need cable connection. If we did buy say, SB8200, is instruction available to set the modem to the RBK53s?
Thank you!!
Message 3 of 10
Mstrbig
Master
Thank you!!
You can connect the Orbi WAN to the Aircube Lan and run the setup for the orbi and stay on satellite.
If going to Comcast, you are correct, you need a DOCSIS modem with a cable connetion.
You would need no directions for plugging in the SB8200. You contact Comcast, give them the mac address of the SB8200, plug the coax in and you are ready to turn on. You would then connect the Orbi router to one of the ports on the back of the SB820. Then you can configure the Orbi router and satellites, following the installation instructions. The Arris SB8200 is a nice fast modem. I have one.
Message 4 of 10
Guru
Message 5 of 10
4UToday
The satilite company will not be available to us so the next best thing in our mountain home is Comcast.
So you are saying, I will have the sb8200 and an Orbi next to each other. Ugh thats a lot of sapce being used.
Thank you for your help!
Message 6 of 10
Guru
Message 7 of 10
Mstrbig
Master
If you are referring to the size, the Arris SB8200 is a small footprint modem, 5.13 x 1.75 x 5.25 inches, compared to Netgear comparible models.
If you are referring to the 2 devices being close together, you can play the Orbi router anywhere you want preoviding you can get a network cable from the port on the Arris SB82 to the Orbi router's WAN port.
Message 8 of 10
Guru
Let us know how it all goes when you get it setup.
Recommended keeping modem and RBR at 6" to 1' ft distance.
Message 9 of 10
Mstrbig
Master
Regarding placement of an Orbi router in conjunction to Internet modem/router. We have installed systems where the Orbi router was 50ft away from the Internet modem/router, connected via Cat5e or Cat6 cable, with no degredation of signal or performance.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3265 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
