Orbi WiFi 7 RBE973
Reply
Orbi AC3000 WEP
Maranzi
Follower
Orbi AC3000 WEP
Hello, I'm considering of purchasing Orbi (AC3000) Wireless to home. At home I have "legacy" home automation system which only can use 2.4Ghz WLAN and WEP Security. Is WEP security possible with Orbi WLAN? Another question: what is recommended way to limit only those home automation devices to access/use the 2.4Ghz / WEP-secured WLAN?
Many thanks in advance for the advice!
//Maranzi
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Streak2
Master
Re: Orbi AC3000 WEP
There is no WEP option for wifi security on the Orbi.
You would have to have a separate and older router to handle those devices or upgrade those devices.
The Orbi has MAC filtering to allow control of what connects where.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 640 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
