- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi AC3000 and iOS devices connection issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000 and iOS devices connection issues
@FURRYe38 wrote:What speed test site or app are you using. I've found that testing for good speedtest servers on Ooklas speed test helps you find what works best first with a wired PC. Other speed test servers maybe more busier than others so you need to find one that gives you constant speed results on a wired PC first. Then use same for wireless devices.
I used a couple. Main one is speedtest.net and also http://internethealthtest.org/ to compare results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You also need to find the sub servers with in Ooklas speed test. There are several distanced test sites that are in your area to choose from as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So after disabling Daisy-chain topology, my PC connects to the router at 2.4Ghz. The router is 30 feet and 2 walls away whiie the satellite is 4 clear feet away from the PC. I need to disconnect and then connect again to get to the satellite; sometimes I need to try this a few times before I get the 5Ghz connection to the satellite. Something is weird in the Daisy-chain functionality that seems to have a wider impact than satellite-to-satellite communicaion.
- « Previous
- 1
- 2
- Next »
