Orbi WiFi 7 RBE973
Reply
Orbi AC3000 mesh network
453Ringo
Follower
I recently switched from DirecTv to a streaming service. I have multiple TVs running throughout the house. Some are connected to via WiFi to the cable provider's modem and othjers are connected to the Orbi Mesh network. I am seeing issues with the ones connected to the Orbi network. They tend to buffer more often than the ones that are connected directly to the cable provider's WiFi modem. Is there a special configuration that I need to add to the Orbi router to prevent this? Also, I am seeing that the router seems to lose connectivity more often now that I am using the streaming service. While the orbi router never indicates that it is rebooting, or has lost connectivity to the internet. The two satellites will turn blue or purple throughout the day.
Any suggestions will be greatly appreciated,
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi AC3000 mesh network
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 404 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
