Orbi WiFi 7 RBE973
Reply
Orbi AC3000 set up with Netgear switch GS108T
kaks
Need help in connecting the AC3000/RBK3000 with the managed switch GS108T
Message 1 of 4
Guru
Re: Orbi AC3000 set up with Netgear switch GS108T
Need  more info on what you're trying to accomplish here.
1. Are you installing a new orbi setup? Or a new switch?
2. What all is being connected?
3. At what step are you struggling with? did you setup the orbi and can't get the switch or vice versa?
Basically we need to know where the problem is to help you.
Both devices have setup guides. If you go to netgear.com/support   , plug in your model number for each and use the manual/guides to help you set them up.
I have an orbi setup with a managed switch. It was basically plug and play like a unmanaged switch. It only changes once you start changing your managed switches settings (vlans, dhcp, etc).
Message 2 of 4
You might get better replies, and find other answers, over in the appropriate section:
Switches - NETGEAR Communities
Message 3 of 4
Guru
What FW is currently loaded?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
https://kb.netgear.com/000045868/What-do-the-LEDs-on-my-Orbi-Pro-devices-mean
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 702 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
