- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
@Bettylou2020 wrote:
I’m trying to set up and i get to where the router tries to join the Orbi WiFi address but it can’t connect and doesn’t come up on my WiFi settings?
New or used system? If used factory reset before attempting to configure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
Are you using a wired PC and web browser to setup the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
I know it can be frustrating.
Start again:
reboot ISP modem/router, reset Orbi router before connecting to ISP router, connect Orbi to ISP router and turn on, run the app to configure the Orbi router, following the instructions. This should get you setup, unless you are having an issue with WIFI on the device you are using for setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
Please try with a wired PC or laptop or wireles laptop and web browser...
No, Using the app
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
I don’t know how to set up with a laptop? I don’t think they gave that option in the set up instructions.
To install and manage your Orbi WiFi System, launch a web browser from a computer connect to your Orbi network and visit www.orbilogin.com.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
I added a pix of the error. I reset router and orbi multiple times. I don’t get the orbi WiFi choice in my WiFi settings
Usually unable to join means wrong username and password. Default username is admin and the password is password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
the PW for the default wifi will be printed on a sticker that comes on a removable slip ring on the RBR and should be printed on the sticker on the bottom of the RBR. This differs from the admin log in for the RBR web page.
Be sure your entering in the correct PW for the default SSID name. Otherwise use a PC, Laptop and web browser to access the RBRs web page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
Is this a Verizon Orbi that you got from Verizon? if so, you'll need to keep in conect with verizon about this. They are responsible for support on there verizon FW developed Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AC3000
