Reply
Orbi - AP mode - random disconnects
zowa
Hello,
I tried to use Orbi (2 units) configured in AP Mode. The problem is: it drops connection randomly, for something like 20 seconds. It happens all the time, like 10 times per hour, at least.
When I configure the same system in router mode, the problem does not happen.
The reason I tried AP Mode is simple: the torrent + DNS problem in router mode.
The current situation is:
- I cannot use router mode because DNS stops when I use torrent.
- I cannot use AP mode because it is not reliable.
Any thoughts?
Thanks!
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 6
Guru
Re: Orbi - AP mode - random disconnects
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 6
zowa
Hello,
Well, I don't  think the wifi environment may be the cause, because it works fine when using router mode. The distance between the 2 units is around 20 feet.
The problem only exists when I configure the units to AP Mode.
I tried disabling daisy chain, it did not solve the problem.
Message 3 of 6
Guru
30 feet is recommended in between them to begin with depending upon building materials. 20 is a bit too close. The router alone can cover up to 30 feet and beyond depending upon building materials.
Try the system with out the satellite. Does the router work ok on it's own?
Message 4 of 6
zowa
The distance is not linear. The units are on different floors.
I just configured it back to router mode, and guess what: no more disconnects.
It is a bug. Netgear does not care.
Message 5 of 6
Guru
"The distance between the 2 units is around 20 feet." This is a factor as well. This maybe too close.
AP or Router mode doesn't matter..
Let us know if it happens again.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 748 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
