Orbi WiFi 7 RBE973
Reply
Orbi Android App
walkerx
Guide
Orbi Android App
I've noticed with the Orbi Android app, running on Pixel 3 XL if I'm connected it to a orbi satellite it will not work and just says can't connect to network, even though I'm connected to it.
If I move so i'm connected to the main orbi router then it works and lets me log in, but then says it can never see the satellites, but if I connect via webpage it shows that both my satellites are connected.
I've already logged this with netgear, but their support has been dismal to the extent of not much support from them
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 19
Accepted Solutions
walkerx
Guide
Re: Orbi Android App
resolved the issue
picked up google wifi - setup in about 20 minutes - all devices working and so is their app
wifi might not be ac3000 but at least everything works
Message 19 of 19
All Replies
Chuck_M
Mentor
To properly diagnose this, you will need to provide some additional details:
What make/model of modem are you connecting to?
What mode is Orbi operating in? (AP or Router)
What is your firmware version on both your router and satellites
What is the status of beamforming, fastroaming and daisychain check boxes
Are either of your satellites hardwired backhaul?
Message 2 of 19
walkerx
Guide
My orbi's are connected to a switch, which is connected to Opnsense router
Orbi is in AP mode
v2.2.1.210
All enabled
Both are hardwired backhaul but have found issue with one, where it states that the backhaul is 5Ghz even after reseting the unit, was previously working via ethernet backhaul
Message 3 of 19
Guru
Is this the only android device you have?
I use a Galaxy Tab S2.
What FW is loaded on the Orbi?
Message 4 of 19
walkerx
Guide
Yes it is the only android device used for connection to the unit
as per post above its on 2.2.1.210
Message 5 of 19
Guru
Possible SW issue with this device or the app. You might remove the app from the device, reboot, then re-install the app.
Something you might ask NG about.
Message 6 of 19
walkerx
Guide
already done all that and as posted in my original post netgear were more than dismal in offering any help
Message 7 of 19
Guru
Might contact one of the forum Moderators to see if they can pass this along. @Blanca_O ]
It's working on my Tab S2. I satellite appears along with connected devices. Can select the satellite and see whats connected to it.
Message 8 of 19
walkerx
Guide
well mine don't work and shows both satellites as offline and for one its showing incorrect ip address, probably would have been easier for me to stay with tp-links and have them setup all over the house as never had issues with them when i used them.
hopefully should get replacement system by tuesday, just hope that works, i should have sent this back last time was having issues with the product losing it settings
Message 9 of 19
Guru
Ya, and having it not show as working in the app, probably is a indication that the satellite is bad as you said in your other thread.
Message 10 of 19
walkerx
Guide
well installed my replacement orbi's
picked up in app, but not one of the units (main or satellites) show what devices are connected and to which satellite, but if i go into device list on the app, it shows devices connected.
if i go to web interface on tablet it shows devices connected and which orbi connected to
Message 11 of 19
Guru
Glad you got the new Orbi working.
Message 12 of 19
walkerx
Guide
got it working, wasn't easy getting it up and running (not as simply as plug it in and away you go), but I also think I shouldn't have updated to the latest firmware as of yet.
Message 13 of 19
CrimpOn
Guru
On my Android Orbi app, I can see which devices are connected by tapping the tiny green spot next to the router or satellite. Show name, IP, link rate, etc.
Message 14 of 19
Guru
What do you think you did that you got it working?
Ya, Orbi isn't the quickest system to get setup and running. Took me a good hour to get my friends setup when he bought his. Smiley Frustrated
Message 15 of 19
walkerx
Guide
@CrimpOn
That is what is supposed to happen but wasn't on mine, its finally showed devices on satellite after a few days.
@FURRYe38
Well its working to a degree, the wired satellite is now showing as not connected in the app, but is on rbr50 gui interface.
Still can't access the app when connected to a satellite, bit daft you have to be connected to the main orbi to see anything.
Message 16 of 19
walkerx
Guide
Even after further reboots, the wired satellite still shows as not connected/online in the app, yet through browser it is fine.
Message 17 of 19
Guru
Possible new bug for the app. You might contact NG support and ask about this:
@Blanca_O
@ErnestTheGreat
Message 18 of 19
walkerx
Guide
resolved the issue
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 6065 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
