Reply
Orbi App Firmware Update Not Working
bklynjosh
Follower
I'm currently running Firmware version 2.3.1.44 on my RBR20 (with one satellite) and need to update to the latest firmware, but everytime I go to update the firmware via the Orbi app it times out. I know I can manually update the firmware by downloading it to my laptop then connecting to the router via ethernet but I would have to buy an ethernet dongle for my MacBook Air, which I prefer not to do.
Anyone else experienced issues with trying to update via the app? Anyone able to suggest a fix? Should I reboot the router?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi App Firmware Update Not Working
Connect the mac book air via wifi to the Orbi system and update the system using the mac. Use Safari to connect to the RBRs web page. You can use wifi connection with a PC to update FW. Update the RBS first, then the RBR.
Fully reboot the RBR and RBS. Power OFF for 30 seconds then back on.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1158 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
