Reply
Orbi App Issues
NotTech
Follower
Orbi App Issues
I can’t get into the orbi app. I tried to do the password recovery but don’t seem to be successful. How else can I get into the orbi app? I do have a Netgear account I know the credentials to.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Guru
Re: Orbi App Issues
Are you trying to connect to the Orib when you at home? the local log in information should work.
What mobile device are you using?
Have you removed the app from the devcie, rebooted device, then re-install app then try to connect it. It should ask you for local log in information. Can you access the Orbi with a PC and web browser?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1262 views
  • 0 kudos
  • 2 in conversation
Announcements
