- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi App Not Working Properly
- Mark as New
- Bookmark
- Subscribe
- Permalink
The orbi app does not seem to be showing devices connected to the satelite units. When I click on the network map and select one of my satelites, it shows no devices connected. When I go into the router settings as a web page and look at the connected devices, it does appear that there are devices connected to the satelite. Howeve, it does not say which satelite a device is connected to. I know these items worked in the past. Now I am not sure what is correct. Is anyone else seeing this same issue? Any fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi App Not Working Properly
On the Orbi web interface, the Attached Devices page shows the Connected Satellites at the top.
Each satellite shows a MAC address.
In the Connected Devices below, items that are connected to the Orbi and satellites show the MAC address of the unit they are connected to. If there are devices connected to more than one satellite, then some should show different MAC addresses than others.
There is an entire community forum devoted to the Orbi "app".
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have downloaded the most recent app and I have to say that it sucks. Nothing that it says is anyway near reliable. It shows my sattelite unit as offline but the IP shows that it is online. Even the deivice count is way way off. I am using 2.5.0.40 F/W and the newest 2.4.10.9 app. Come on Netgear!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also noticing when updating the attached devices list, the changes don't fully take. I just installed hotfix 2.5.040 and I'm on 2.2.10.527 of the Android app. My list is also incomplete as well and shows MAC addresses which aren't on my network. Hoping for another firmware update soon!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MachoMan85 wrote:
I’m having the same problem, I purchased the new AX6000 RBR852 and says no devices connected when looking at both router or satellite on the network map. Paid $699 for this product and the app doesn’t even work. VERY FRUSTRATING!!!
Suggestions:
- Use the web interface instead of the "app".
- Post about the app in the community forum devoted entirely to the "app", rather in this forum where most of the people who check the forum appear to be more comfortable with the web interface. The app forum is here: https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
- Post about the new WiFi 6 (AX) product in the forum devoted to that product. Again, most of us who monitor this forum have the residential (WiFi 5) product and have no experience with the WiFi 6 product. https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Ukgrauel & caremd99,
May you try performing a factory reset on the Orbi units and let me know if your issue persists.
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello caremd99,
Thanks for taking the time to perform a reset on your units. I'd like for our Support Team to look into this further. If you'd like to be contacted, please send me a private message with your contact info and serial number.
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey. I have the same problem and in my situation, I narrowed it down to one device, my Denon AVR-X4500H. When that device is not connected to the network, all devices show up in the device list of both the router and the satellite, but as soon as the Denon joins the group, everything freaks out and all devices disappear from the router and satellite and in the Device Manager screen, the devices are no longer sorted by the band that they are connected to but simply by WIRED or WIRELESS. I had the RBK53 kit before i got the RBK852 and it did not behave in this manner at all. I don't believe this is an app issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having this same issue. App shows Satellites as not connected although it clearly sees them showing in the network map. They all show firmware each V2.5.1.8. Just started with the last update. Reset satellites, resynched or tried too...nothing but not connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
