- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Blocking Office L2TP VPN After Time - Solved?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm hoping this might help someone with the same problem.
The Issue:
After some period of time (we're talking about weeks or months here), the Orbi stops allowing my home PC to connect to my work L2TP VPN. It all works perfectly at first, then all of a sudden one day I can no longer connect. After turning off firewalls, configuring unneccesary port forwards, factory resets, firmware updates, enabling my PC IP on the Orbi DMZ and tons of other things I've tried between the PC and the Orbi to get the VPN connecting again, the PC VPN connection attempt never gets passed the Orbi once it's decided to start blocking it.
The Previous Solution:
Stumped and flabbergasted, I replace the Orbi with a new one and everything works fine again. I don't get it.
The Solution Without Replacing the Unit:
It happened again today with the third unit, and I tried something different. I enabled the VPN service on the Orbi itself and the instant I did that I was able to connect to the work VPN again. Turning on that service seemed to unblock whatever was being blocked at the Orbi firewall. I guess time will tell if it decides to start randomly blocking the VPN again, but for now, this worked even though I have no use for the Orbi VPN service to be on.
If it does block VPN again, the 4th unit will definitely NOT be another Orbi.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply and raising your scepticism. The only thing I can think of is that VPN traffic is arbitrarily being blocked and enabling the service forced the Orbi to open the traffic again. That does seem reasonable for restoring the traffic, but why it's getting blocked in the first place is very odd.
The Orbi is connected to a Frontier cable modem in bridged mode passing the public IP to the Orbi. A lone PC is plugged into the Orbi via ethernet (the wifi is for phones and TV's and such).
Each time this has happened I've spent hours on the PC, the Orbi and the office VPN (Ubiquiti USG) trying to find where the blockage was which all signs point to the Orbi router.
When this problem has occurred 3 times now, each time there has been no change to the Orbi, the PC or the office VPN. It just happens out of the blue. I'm very surprised that a factory reset of the Orbi did not resolve the issue. The PC is only really used for remote access so there are no files or anything on it, so I also did a factory reset of the PC to no avail. Logs on the USG at the office show no incoming connection attempt.
In two prior cases, replacing the Orbi with a new one with it's default settings resolved the issue immediately. In this last case, after examining a bunch of things that are common with VPN connection issues, the instant I enabled on the OpenVPN service on the Orbi the PC connected to the work VPN again.
After subsequently disabling the OpenVPN service, the PC's VPN connection to the office is remaining solid again after having been unable to connect all day.
I'm going to do an experiment. I'll leave the OpenVPN off and see if this weird behavior happens again. If it does, I'll only enable the OpenVPN service and see if it lets the traffic through again.
-Ale
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Blocking Office L2TP VPN After Time - Solved?
Glad that you are "back in business", but sceptical that enabling OpenVPN on the Orbi was actually a solution.
What (exactly) is the Orbi connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
-Ale
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to mark your thread as Solved so others will know.
Thank you.
@Aletheion wrote:I'm hoping this might help someone with the same problem.
The Issue:After some period of time (we're talking about weeks or months here), the Orbi stops allowing my home PC to connect to my work L2TP VPN. It all works perfectly at first, then all of a sudden one day I can no longer connect. After turning off firewalls, configuring unneccesary port forwards, factory resets, firmware updates, enabling my PC IP on the Orbi DMZ and tons of other things I've tried between the PC and the Orbi to get the VPN connecting again, the PC VPN connection attempt never gets passed the Orbi once it's decided to start blocking it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Marked as resolved. I will come back and update this post if I find something different.
-Ale
- Mark as New
- Bookmark
- Subscribe
- Permalink
