Orbi WiFi 7 RBE973
Reply
Orbi Circle Connectivity
jlcarpenter
Tutor
I am having trouble with the circle app when used with my Orbi router with built-in Circle. When I open the app it says cannot connect to circle. I try to reconnect with the same issue. I have restarted the app and the router with the same result.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
CrimpOn
Guru
Re: Orbi Circle Connectivity
Not to put you off, but my observation is that there are not a lot of Circle users on this forum.
Netgear has an entire community forum dedicated to Circle: https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
You might get a more informed response (and more quickly) by posting on that forum.
Disclaimer: I have no need for Circle, dislike subscriptions, and thus have not ever activated Circle, not even for a test.  Maybe someone else will offer a solution?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 519 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
