- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Configuration
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi Configuration
I like the product but there are two decisions that Netgear has made that causes me issues. WHY?
1. Having the same SSID for 2.4 and 5 GB bands. In the past I had one for each and it was much easier to pick the right band for each device.
2. Having the same channel on 2.4 for the base and the satellite.
I choose you over some other products for the AP/bridge mode option. As a network pro I have a lot of equipment both wired and wireless. These design choices that Netgear has made make it harder to recommend this product.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Configuration
1. Is required for seamless roaming and complete home coverage with only 2-3 APs.
2. Why is this an issue for you? Seems to work well enough.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have equipment that does not like this configuration. In the past I had two HP comercial access points, one for 5 GhZ and one for 2.4. Each had a unique name. As I installed devices link ring doorbells and Canary cameras on the outside of my house, I needed more coverage. At one time I had an TP-link AP connected via power over ethernet to cover these devices with a unique SSID. My goal in installing a whole house system was to have a simliar solution. But not being able to choose the WiFi band has caused problems and causes the devices to go offline.
I am the only neighbor who uses 5 GhZ, so I do not get the issues with other access points, but I need to be able to force devices to choose it.
