- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi - Configuring wired ethernet - backhaul and fronthaul RBR50 and RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to setup my ORBI RBS50 with a wired backhaul. I have it set up like https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy..., but it still says it is connected via wireless. I only have one Satelite.
I would assume that if the ORBI decects a wired connection (which is a boat load faster) it would use that instead of trying to connect via wireless. However we all know what ASSUME means, so any help would be great.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi - Configuring wired ethernet - backhaul and fronthaul RBR50 and RBS50
I just updated both Sat and Router's firmware to 2.1.3.4 and still get the same thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to factory reset the router and satellite then set up from scratch.
Set up the router first. Then add the satellite via wireless. After this, then connect a LAN cable between the router and satellite. Give 5 minutes for the system to re-configure and come to ready on wired back haul.
Any network switches between the router and satellite?
Cat 6 LAN cable recommended.
