- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Current device does not support Armor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello to all. I have an Orbi RBK53. When I manually updated the firmware to version 2.5.1.8 I began getting a message when I would try to connect remotely that says...
Current device does not support Armor, Press Ok to go to Notification Center
and once I am in the Orbi app, Armor does not show...
I reiterate, connecting with the Orbi app locally, I do not get this message, nor did I receive it with firmware 2.5.0.XX, only when I updated to 2.5.1.8.
Any ideas on what I can do or who I need to contact? Attaching pics...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Current device does not support Armor
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Factory reset the RBR and setup from scratch. Use a wired PC or laptop connected to the RBR, Walk thru the setup wizard. When you get to the end of the wizard and complete it, Armor should present a window to enabled it or not.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks FURRYe38. Although not sure why in the Armor app because the Armor app is not sending me the notification, it comes from the Netgear Orbi app. But I will give it a shot. I also should have mentioned that I have been through resetting the Orbi, I do that after any update and bi-monthly anyway because unfortunately the firmware that Netgear pushes out is disgustingly buggy. I'm just waiting for UniFi to get their home mesh system ironed out so I can jump ship because Orbi has gotten to be more headache that any advantages it gives.
- Mark as New
- Bookmark
- Subscribe
- Permalink
