- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi DHCP address range configurable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would *appear* that, no matter what IP and subnet mask you tell Orbi to use, DHCP will only assign the first 252 addresses.
(i.e. If you change to 172.16.0.1\22, Orbi will only open the last octet up for DHCP, and only allow addresses ending in 0.2 through 0.254.)
Is this a limitation of the system or is there a way to configure the third octet of DHCP addresses and I'm just missing it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi DHCP address range configurable?
Hello Ed1chandler
Can you send me a PM with your name, Email, and phone number I want to get you to support to work with you on this issue.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're going to need to explain how to do that, since it's not apparent either from this screen, or from your profile screen.
Meanwhile, the Orbi app won't connect either. I see a lot of people having that problem. I guess I'd like to know the app (iOS) knows to connect with your particular Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
To send a PM: Click on his username. On his profile page there is a big button at the top left that says "Send this user a private message."
- Mark as New
- Bookmark
- Subscribe
- Permalink
If that were the case, I wouldn't have asked. It says, "Contact me", but only shows his online status and nothing is clickable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
However, *your* profile does have the big button you mentioned.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Weird. Darren's profile has the PM button when I view it. If you would like to PM me your details I will forward them to Darren for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Came back yesterday (or maybe the day before) and I *could* PM him ... and did so. (weird)
Anyway, would sure like to be able to serve addresses across a class B. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still no reply from that PM, so this is still unresolved. Thanks.
