- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Dropped connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi system is pure garbage and a waste of 400 dollars. Constant lose of internet, terrible WiFi speeds, dropped connections , the list goes on. I have even called support and the only option was to change my WiFi channels. The product is half baked, and customers should get their money back. Don’t buy this product.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi is garbage
Agreed. I keep getting constant drops on anything connected to my satellite. Pinging the router from my desktop that's wired into the satellite has 1% packet loss (attached)!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi is garbage
wrote:Agreed. I keep getting constant drops on anything connected to my satellite. Pinging the router from my desktop that's wired into the satellite has 1% packet loss (attached)!
I had the exact same problem as you do. Reverting back to firmware V2.0.0.74 fixed it in my case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi is garbage
mine has been working ok since November. several auto firmware updates ( i don't do beta). simple router to sats setup and dozens of devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi is garbage
mine works brilliantly. hope you find something that works for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi is garbage
Reverting firmware can help. Keeping it there is a big problem. After following the unofficial process to try to disable auto-updates, I keep getting upgraded anyway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi is garbage
wrote:Reverting firmware can help. Keeping it there is a big problem. After following the unofficial process to try to disable auto-updates, I keep getting upgraded anyway.
I was on the same boat as you. I had to block all the internet access from the Orbi units without affecting the devices conected through them using my firewall.
