Reply
Orbi Firmware Beta Testing
tdroz1
I'm interested in beta testing Orbi firmware if you're still looking for testers.
Thanks,
Tim
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Retired_Member
Not applicable
Re: Orbi Firmware Beta Testing
Nice
Most of the folks who do manual firmware updates end up feeling like a beta tester
Message 2 of 5
tomschmidt
Virtuoso
Not just manual updates, but auto-updates prior to v2.3.x where they turned it off.  And we were Alpha testers for v2.5.0.x, which broke just about everybody!
RBK53 Orbi AC3000 Tri-band WiFi System (RBR50v1 router and two RBS50v1 satellites) running v2.5.1.16 firmware
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 3 of 5
Guru
You can join the beta forum if you like to gain access to it. Contact @Christian_R
Though there hasn't been any betas for a while for Orbi AC.
You can also give Voxels FW a try if you like:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1839...
Good Luck.
Thanks,
Tim
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 4 of 5
Retired_Member
Not applicable
That would be just manual updates TODAY.  Auto is suppose to be those that contain crtical updates and possibly the bugs worked.  And yes I was around when all the whiners complained about NG basically pushing everything. "Oh you broke my system"  Today, it's the same chant, however, now it's the whiner him/herself who only have themselves to blame.
What I've not heard is how any of the whiners today update their system?  The acted as they had some sort of insight of which was the best FW to update to.  Really?  Good luck with that.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1434 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
