Discussion stats
  • 6 replies
  • 975 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Orbi Firmware V2.3.0.32
Netgear site still shows that Orbi Firmware V2.3.0.32 is NOT to be installed in Australia (so I assume also NOT in New Zealand).
Is this still correct, or can NZ'ers and Aust'ers install this update on RBR50's and RBS50's?
Thank you.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 7
Accepted Solutions
Highlighted
Guru
Re: Orbi Firmware V2.3.0.32
Thanks for letting us know. Please mark your post thread as solved.
Enjoy.
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 7 of 7
All Replies
Highlighted
Guru
Note:
If you’re manually updating the firmware using a browser, you cannot update the firmware directly to v2.3.0.32. You must first update the firmware to v2.2.1.212.  After updating the firmware v2.2.1.212, your Orbi router will reboot, and then you can update to v2.3.0.32.
If you are located in the following regions Japan (JP), Australia (AU) and Canada (CA) please hold off updating to FW 2.3.0.32
Though NZ is not mentioned. since your in the same region as AU, I presume this includes NZ.
https://kb.netgear.com/000060603/RBR50-RBS50-Firmware-Version-2-3-0-32
Message 2 of 7
Highlighted
NETGEAR Moderator
Hi @Mrpopup
Welcome to NETGEAR Community!
Were you able to update the firmware?
Blanca
Community Team
Message 3 of 7
Highlighted
Hi,
No have not updated as yet as the ‘hold off’ message is still showing on the Netgear website for AU area users.
Thanks.
Cheers.
Message 4 of 7
Highlighted
NETGEAR Moderator
Hi @Mrpopup
A new firmware (v2.3.1.44) was posted and it fixes the firmware update issue for Japan, Australia and Canada. Please click link to download the said firmware.
Blanca
Community Team
Message 5 of 7
Highlighted
Hi Blanca,
Thank so much for the post and update.
Have successfully updated both my RBR50 and RBS50 to v2.3.1.44, via v2.2.1.212.
No problems encountered at all.
Appreciate the interest.
Cheers
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 6 of 7
Highlighted
Guru
Enjoy.
Message 7 of 7
