Reply
Orbi IOS Application Failing on IOS 15.0 Beta 2
Art_Masson
Guide
Just for info.  I've just upgraded my Iphone to IOS 15.0 Beta 2.    Realize this isn't supported, but would like the development team to be aware.
As soon as try to launch the most recent Orbi application no longer runs.  I get an error that WIFI isn't available (but clearly it is and other applications work fine.  Here is a picture of the error screen. IMG_0271.PNG
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 6
Accepted Solutions
Art_Masson
Guide
Re: Orbi IOS Application Failing on IOS 15.0 Beta 2
Problem Solved !  I had to disable "ICloud Private Relay" under WIFI details/settings.  Once I did that, the Orbi App was able to detect the Orbi WIFI network.
Message 4 of 6
All Replies
Guru
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 6
Art_Masson
Guide
Thanks...have reposted in the Orbi area.
Message 3 of 6
Art_Masson
Guide
Message 4 of 6
Guru
Thanks for letting us know.
Enjoy. Smiley Wink
Message 5 of 6
schumaku
Guru
Pretty crappy if a "privacy service" does pick up DNS queries intended for local usage but does sent the related traffic to some proxy in the Internet and the fraffic is leaving over some local proxy again ... where it almost certainly won't see any LAN local device like an Orni system. Once more, Apple privacy at it's best ...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 410 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
