- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Installation with rented Spectrum Modem/Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi -
I currently have a rented modem/router from Spectrum (Los Angeles - 90026). Technicolor (TC8715D). I also use Apple Airport's. (all dated I know). I want to purchase an Orbi Wifi Mesh Network system. A few questions, as I'm not that savvy here.
A) Do I still need a router/modem after I buy the Orbi AC3000 (RBK50).
- If yes - do you recommend I stop renting mine from Spectrum and purchase a new one?
- If yes - any recommendations on what I need to complete my set up?
My hosue is 3 stories. is the 2 pack enough?
I greatly appreciate all your support & information. I've seen a lot of great answers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Installation with rented Spectrum Modem/Router
@dsmith611 wrote:.......
You still need a modem that has a coax cable interface that your ISP provides. The existing router will do, but if there is a simpler modem with no routing nor wifi capabilities that will be even better.
@dsmith611 wrote:........
It depends on the area of the floors, the building material and if you have dead spots in the house. Generally 2-pack AC3000 nodes will be enough up to 4500 sq ft. If you have large floors and metal/cement building material then I would recommend one unit per floor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much. For simplicity and efficiency, is there a Netgear Modem you recommend?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dsmith611 wrote:Thank you so much. For simplicity and efficiency, is there a Netgear Modem you recommend?
If you're not using the router for anything else like telephony or TV, then it's enough to have a MoCa adapter like Netgear MC1001.
https://www.netgear.com/images/pdf/NETGEAR-MCA1001v2-D-05092014-2.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Check to see if your ISP supports NGs CM1000 or CM1100 modems. These do not have any built in router.
@dsmith611 wrote:Hi -
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! I do use the router for my Apple TV & wireless calling. So I need something to replace my rented modem/router that will support Spectrum (Los Angles, CA 90026) that will support my orbi mesh system, apple TV, etc.
