- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Internet Freezes Every 30 Seconds
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the Orbi RBK40 (i think) the guest wifi doesnt freeze every 30 seconds, just the main one, Ive tried everything, I cant figure out why its happening.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Internet Freezes Every 30 Seconds
Is the Orbi system operating in Router or AP mode?
@MaxwellStyler wrote:With the Orbi RBK40 (i think) the guest wifi doesnt freeze every 30 seconds, just the main one, Ive tried everything, I cant figure out why its happening.
