Bruce-H
Mar 22, 2021Aspirant
Orbi LBK1220 LED white red pulse before 100% data used
I have an Orbi LBK1220 - 4GX AC1200 Dual-Band Mesh WiFi System router. The LED recently started to pulse white red way before I had used 100% of the data. In fact, I hadn't even used 50% of the data when it began to occur. The LED lighting will go though a cycle where it will pulse white red for a while, then go solid red for a short while, then white, then return to blue, and then the cycle will begin again. My internet connection does not appear to be affected by all this and remains stable and strong. I have tried resetting the router - no effect. I have tried reinstalling the firmware (version LBR1020-V2.5.1.18.img), but that also has no effect. Any assistance will be appreciated. Thanks, Bruce.
1 Reply
I recommend you post about this over in the Orbi LTE forum:
https://community.netgear.com/t5/Orbi-LTE/bd-p/en-home-orbi-lte
Thank you.
