Orbi WiFi 7 RBE973
Reply
Orbi Light
Orbi Light
Is there anyway to disable the orbi light? It goes from steady blue, to steady yellow. I'm fine with the connection speed that I'm geting since the router & satelite are so far apart. But the Satelite keeps insisting that I should know that they are so far apart. Any help? If I block the light with tape, would it eventually damage the device?
Message 1 of 2
Re: Orbi Light
dont believe so , why have you got them so far apart
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2256 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
