- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi MR 2.1 Update 3/23/18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi MR 2.1 Update 3/23/18
LOL , you really think the 19 pages of this thread speak about people like you, all is fine, orbi works fine, i'm very happy.... NO
i'm french and buy the orbi because it seems good but never works good for me, i keep my old router to get backup because the orbi doesn't work correctly.
I'm not a competitor or something else, just a user that see my old router working very good and orbi very bad , but i need the orbi powerfull wifi.
So there is a problem with orbi and need a fix, that's all.
There can't be specific use, a router is a router, work with all devices, like my old router, so no need to tell you what's device i have, it must works with ! i don't make my device myself ! it's apple, google, asus... all known device that work with every other routers ! but orbi ! (or not longer if it works some times )
maybe it work for you, cool for you.
Look at the debug page of the router ( http://192.168.1.xx/debug.htm ) and look at you uptime, mine is never more than 2 days... (satellite is ok )
Orbi has problem, don't say "no", it's a fact.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And for your information, i've sent many logs to netgear to help them to fix the problem (2 weeks ago).
So they know all about my devices...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I should be more clear...all I did was the factory reset. I didn't turn anything off.
I did enable circle and now it seems that I have to setup a new instance since I don't know how ot move the profile...
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to contact NG support directly and they'll need to help you out since you don't seem to want any help here. No everyone has had bad luck in there Orbi units. If your's is not working then return the unit or contact NG support.
Good luck.
@chsalmon wrote:LOL , you really think the 19 pages of this thread speak about people like you, all is fine, orbi works fine, i'm very happy.... NO
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, you'll probably have to set that up again. I don't know if you can move profiles. Something you might contact NG support and ask about. I don't use Circle.
@wegunterjr wrote:I should be more clear...all I did was the factory reset. I didn't turn anything off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
checked to make sure, thought it was enabled, but it wasn't.
I enabled Disney Circle and my existing setup from my app was remembered.
Awesome! so far, so good with 2.1.3.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad that was a simple fix. Enjoy.
@wegunterjr wrote:checked to make sure, thought it was enabled, but it wasn't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased an Orbi RBK53 from Costco (3pk) last Friday.
Love the overall coverage I am getting, but I am getting serveral drops/disconnect from the Internet. I am using an Arris SB6183 with Xfinity Internet.
I keep reading on here that people are having better luck with a beta firmware, but when I go
to the support page for my Orbi I don't see anything listed as Beta.
Any help to direct me towards a firmware that would help with my issues would be
appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the link to the beta firmware:
https://kb.netgear.com/000055562/RBR50-RBS50-Firmware-Version-2-1-3-4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Everyone
I have Fixed the links for the RBR50 and RBS50 downloads and we also added the beta firmware for the RBW30 wall plug.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply. I have updated my router and satellites
to V2.1.3.4. I hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its recommended to factory reset and set up from scratch after updating to this version of FW. Hope it works well for you.
Whats the size of your home? Sqft?
What is the distance between the router and satellite?
@LeinieDrinker wrote:Thanks for your reply. I have updated my router and satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
Count me in for one of the lucky people with a very stable V2.1.3.4 installation. My home environment + devices is such that I have no problems. My uptime per http://orbilogin.net/debug.htm is 17 days. Can anyone beat that?
CPU Load | 7.38916% | |
Memory Usage(Used/Total) | 195MB/495MB | |
Flash Usage(Used/Total) | 32MB/4GB | |
Network Session(Active/Total) | 1146/65536 | |
System Uptime | 17:02:55:02 |
BTW, I'm lazy and have not been doing factory resets before each firmware upgrade/downgrade. So far it's been working fine for me, but if I ever experience any performance issues then I would try factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting your expriences. Good up time...Lots of devices too. Wow.
Enjoy.
@Mikey94025 wrote:Count me in for one of the lucky people with a very stable V2.1.3.4 installation. My home environment + devices is such that I have no problems. My uptime per http://orbilogin.net/debug.htm is 17 days. Can anyone beat that?
Number of Satellites: 3Number of devices: 54
CPU Load 7.38916% Memory Usage(Used/Total) 195MB/495MB Flash Usage(Used/Total) 32MB/4GB Network Session(Active/Total) 1146/65536 System Uptime 17:02:55:02
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DarrenM wrote:Hello Everyone
DarrenM
Thanks for the update Darren.
Waiting anxiously for the RBS50Y beta firmware to drop 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nice uptime Mikey94025 ! need it...
i wonder if the temperature can reboot the router ?
i see the log thermal-log1.txt and the sensor seems to be ok but maybe sometimes overheat and then reboot ?
is it possible ? i don't know why, but why not, i could try to make it colder... (orbi in the fridge)
log :
Thermal config for wifi0
enable: 1, dc: 100, dc_per_event: 2
level: 0, low thresold: -100, high thresold: 110, dcoffpercent: 0, queue priority 7, policy; 1
level: 1, low thresold: 100, high thresold: 120, dcoffpercent: 50, queue priority 7, policy; 1
level: 2, low thresold: 110, high thresold: 135, dcoffpercent: 90, queue priority 7, policy; 1
level: 3, low thresold: 125, high thresold: 150, dcoffpercent: 100, queue priority 7, policy; 1
Thermal stats for wifi0
sensor temperature: 55, current level: 0
level: 0, entry count: 0, duty cycle spent: 7690
level: 1, entry count: 0, duty cycle spent: 0
level: 2, entry count: 0, duty cycle spent: 0
level: 3, entry count: 0, duty cycle spent: 0
Thermal config for wifi1
Thermal stats for wifi1
sensor temperature: 54, current level: 0
level: 0, entry count: 0, duty cycle spent: 7687
Thermal config for wifi2
Thermal stats for wifi2
sensor temperature: 43, current level: 0
level: 0, entry count: 0, duty cycle spent: 7674
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
so I have been following the hundreds of posts in this thread as well as those prior to this one and for me the only reliable fix has been to split the 2.4G and 5G SSID's using Telnet. No matter what has been tried (and before anyone says it, I have factory reset numberous times both via website and paperclip method as well as trying every possible combination of mu-mimo, fast roaming, beamforming and daisy chain) the only thing that works for me is splitting the SSID. With the SSID combined I get numerious drops or issues connecting to internet etc. The main thing with this firmware is that I haven't had to keep rebooting the satellite to get Internet back at times but all in all splitting the SSID (like we used to have th options back in v1.x of the firmware) is the most reliable but naturally that defeats some of the object of using a mesh type setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@andygodber wrote:@DarrenM where is the link for the RBW30 beta? I can only see 2.0.1.2 (plus older).
http://files.netgear-support.com/go/?a=d&i=x990UeDEdo also on the first page of this thread
- Mark as New
- Bookmark
- Subscribe
- Permalink
BETA: A beta version of a program is an unfinished version released to either the public a select few or whoever signs up to beta test it for bugs or glitches.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try and be patient ... it sucks but they are working on it.
Im using a newer beta for about 12 hours now ....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@steve8411 wrote:Try and be patient ... it sucks but they are working on it.
I've been on 2.0.14 (roll back) for nearly 2 months. Averaging disconnects once a week
- Mark as New
- Bookmark
- Subscribe
- Permalink
