- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi MR 2.1 Update 3/23/18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi MR 2.1 Update 3/23/18
@steve8411wrote:No fast roaming and no daisy chaining.
Gonna set a static IP on my IPad and see if I lose the connection...
I have fast roaming enabled with no daisy chain, no beamforming, no mu-mimo
I did Statically assign chan 1 - 2.4G and chan 48 to 5G (no auto)
I have 2 iPads, 1 Android Tablet, 3 iPhones, 1 Android Phone without any of them dropping.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Elywrote:I have a 1GBs connection from Comcast which I always get close to over Ethernet. However I never got even close to that over wireless before. My speed improved from 200MBs before to over 320MB/s over wirless after this update. That's over 100MB/sec difference right there.
That's all I'm gonna say for now.
@FURRYe38wrote:Just FYI, current wireless technology doesn't support 900+- speed testing. At most you might see 500mb. Too many factors llike client HW, design, connection rates and environment. Hard to see thruput speeds like that on wireless.
The Orbi uses a 2x2 radio for the fronthaul network. This has a theoretical max of ~866 Mbps (5 Ghz, AC). In normal "real-life" environments, you can expect to see about 2/3 of this theoretical max. I think the absolute best I've ever seen in my testing is in the ballpark of ~620 Mbps, but usually it's closer to the 500-550 range. One of these days, I'll get around to setting up an iperf server so I can do local-only tests that don't rely on the outside network, which is the only way to really get an accurate view of you WiFI performance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am now at 24+ plus hours and everything is still running perfect (see post #36 for my original post). Did not have to reboot anything, all my Wifi light switches, Phones, Smart TV's, laptops, Satellitle TV... all working perfect. This is a winner so far for me, most of my problems with 2.1.2.18 were within 18 hours guaranteed so I am happy I have made it past that point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ktoonsezwrote:I am now at 24+ plus hours and everything is still running perfect (see post #36 for my original post). Did not have to reboot anything, all my Wifi light switches, Phones, Smart TV's, laptops, Satellitle TV... all working perfect. This is a winner so far for me, most of my problems with 2.1.2.18 were within 18 hours guaranteed so I am happy I have made it past that point.
Great news! hopefully this will be the case for those experiencing issues with previous firmware versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll give this try soon as I get a chance this weekend.
@mealtowrote:
@FURRYe38wrote:Yes seeing same thing with Wifi Sweetspots, ranging from 300 to 400+Mb. I presume this is between device and router only and not ISP services.
Looking at the About info, its seems only to find spots in the room best for your routers and such. So, ya, only between the mobile device and router. Which speed if your close will be high and are also testing max speeds of your mobile device as well.
Did you try running Wifi Sweetspots while connected to satellite versus router? If so, compare it to my numbers and see where we stand.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi MR 2.1 Update 3/23/18: poor backhaul connectivity.
Upgraded my RBK50 from V2.1.2.18 to V2.1.3.4 and now I'm facing poor backhaul connectivity.
Any suggestions from this community?
PS. The router and satelite have not moved location.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Make sure you upgraded the Firmware on both the Router and the Sat.
- If you did, perform a factory reset on just the Sat and see if that helps.
- If not, then also perform a factory reset on the Orbi Router as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply.
I have not done a factory reset. Will do that and report back later...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory resetting the satelite did the trick. Backhaul connection is good again.
Thanks!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Supertramp11 same here, i have tried disabled fast roaming / beforming and daisy chain, finally found that disable fast roaming and Mu-MIMO makes backhaul good again.
before fast roaming/beforming and mumimo are all on and backhaul was good
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have updated my two RBS50 satellites and the RBR50 router to 2.1.3.4. Now, one satellite won't sync, and the other shows a backhaul of "Poor". Before, I had "Good" for both satellites. I did have multiple dropouts, however. These units have been problematic for me since day one with multiple firmware updates and excuses from NetGear.
I factory reset the router and both satellites 3 times now with the same results. I'm dont wasting my time with these.
NetGear - get your **bleep** together. What a terrible product. I will donate these to Goodwill.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ckimmelshuewrote:I have updated my two RBS50 satellites and the RBR50 router to 2.1.3.4. Now, one satellite won't sync, and the other shows a backhaul of "Poor". Before, I had "Good" for both satellites. I did have multiple dropouts, however. These units have been problematic for me since day one with multiple firmware updates and excuses from NetGear.
Just reboot your sats.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I performed several hard and soft reboots/restarts, to no avail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ckimmelshuewrote:I performed several hard and soft reboots/restarts, to no avail.
Hard reset the satellites and router (paper clip in reset hole till amber light starts blinking).
Set up the system from scratch as if brand new. DO NOT restore from a backup made from a previous version of firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As stated before, I performed several hard and soft reboots. I also started completely from scratch. The Orbi system is now boxed up and ready for donation.
I picked up an Eero system and I'm now back up and running quickly. I'm getting better coverage in "pocket" areas with the Eero.
- Mark as New
- Bookmark
- Subscribe
- Permalink
DO a FULL FACTORY RESET on the ROUTER and SATELLITE(S)!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did, and I'm done doing them now. Crap product with even crappier firm and software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A day after updating, and so far no problems. The apparent issue I was having with iOS devices was very intermittent, though, so only time will tell. Will let it bake...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you need to phone contact NG support and have them help you. Others are having good luck with Beta FW.
@ckimmelshuewrote:I did, and I'm done doing them now. Crap product with even crappier firm and software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
We hope the next beta available for your system will be even better.
@markbaker007wrote:
The orbi mesh system has greatly improved our signal and speed in our 2,000 sq feet home, we have coverage in all rooms, however in the orbi app I do get satellites showing n/a or none, but the router shows them as being connected in the router Web page and all is good. We are on 2.0.0.56.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got this on Wednesday. Worked fine for almost 24 hours then dropped my internet connection. Switched back to my Velop and all was fine. They released this and I decidedx one more try. I reset the system reloaded the firmware and it seemed to be working pretty good. Then I started up on setting up my ring cameras and august locks. Both of therse reported a poor wifi strength. Which I thought was strange as I was within 20 feet of the satelite and it was on a wired backhaul. So I started looking into this some more and noticed standing within 8 feet of the Satelite both my ipad and iphone only got 2 bars on the signal strength.
I am pretty sure I am done with Netgear now. This is getting to be a pain each time they make a change to reset all this up just to find out they still did not get it done right. I have decided netgard products are not worth all this time. So its back in the box. I am not sured i even want to give this system to anyone i know. All it has been is trouble the last few months.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I installed this las night. So far its positive, but i can't comment further yet. I installed router and updated sattelites and did a factory reset on the router. Will have better idea in a week or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am still going strong today sitting at about 48 hours total. All is goooooooooooooooooooood. Not sure why a few people are having such huge problems :-(. Just curious if the people having so much troubles have Apple products on the network? If so they are all probably smearing the network with there AppleTalk tryin to connect to AOL!!!!
