- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi MU-MIMO Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello. Is the MU-MIMO feature in the Orbi wireless system limited to the dedicated band between Router and Satellite only... or will the MU-MIMO feature also extend to devices that support MU... in addition to the isolated band dedicated to the router/satellite? In other words, with devices that have the ability to decode a MU-MIMO signal, will the Orbi also benefit these devices (i.e. - with MU-MIMO) while simultaneously dedicating a band to the Satellite, or do the remaining two bands, which support all other devices (minus the Satellite), revert to a SU-MIMO configuration?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi MU-MIMO Support
Hello PDIGS44
Yes all devices with Mu MIMO support will benefit as it is on the router and all the bands not just the 1 to the satellite.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks again for your replies Darren. Much appreciated. Sounds like you guys (and gals) at NG hit the nail on the head with this system. Glad I pre-ordered.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
just fyi here
you need 2 or more mu-mimo clients to take advantage of mu-mimo , most of us dont have any mu-mimo clients yet
tbh im not overly excited about mu-mimo as its benefit is quite limited with todays adapters
pete
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Someone else pointed out on costco review of the orbi that Beamforming nad Mu-MIMO are off by default? Netgear, why have them OFF by default?? I just enabled mine and seems to really help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
the primary reason they are off is some clients are having issues with it on , if you dont have any clients having issues its fine to leave them enabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
checked with .18 firmware and stability of wi-fi connections with both iHome airplay devices and Nest Products goes from rock solid to intermittent drops for 1-2 mins at intervals of 1-2 times per day. I'm shutting these off and crossing fingers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So I guess the question then is WHEN can this be turned on? I would love to be able to use Explicit Beamforming (tied directly to MU MIMO) however your present advice is dont use. Is there a timeline when this will be working?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I've left Beamforming disabled and turn MU-MIMO on. I don't see why they would both need to be set the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
im guessing it will be when the dev team figure out a fix for the apple clients ( and others ) connectivity issue , as the reason to turn both off is to help with the issues
and again mu-mimo is of little value to any one at the moment anyway as there are ni mu-mimo clients yet and even when there are mu-mimo clients you wont notice much difference if any in the day to day running of a home wifi system with its many clients
byw your understanding of explicit and implicit beamforming is a bit off track
implicit beam forming is where the riouter uses beamforming to help older non AC clients , eg wireless N and g etc and is of some marginal benefit as only the router trach the client device , the client ( non AC ) has no way of tracking the router position
explicit beamforming is part of ( but not compulsury part of ) the wireless AC standard and requires both router and client to have it enabled for it to work correctly
however mu-mimo is not tieed to nore is it part of explicit beam forming and both work separtly and independent of each other
