- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Main vs Guest Network Speed difference
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi wondering if anyone has noticed the same issue I am having and knows of a solution.
I have guest network enabled and for some reason the guest network has faster download and upload speeds and less latency than the main ssid?
Main
Download around 90
Upload around 15
Latency around 15ms
Guest
Download around 300
Guest around 20
Latency around 12ms
Any suggestions appreciated!
Thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Main vs Guest Network Speed difference
Is the Orbi system operating in Router or AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just got the system
Updated both the Orbi Router and Satellite to the latest firmware.
Sagem f3284dc, as it has wifi built in and as there was some conflicts with some pages not being accessible even after setting the NG ip in the DNZ and passthrough and it still not working the router is now set in Bridge mode.
Orbi system is operating in Router mode.
After some more testing the speed seems to vary A LOT on both the regular SSID and the guest SSID.
E.g. last night it was 130Mbps, this morning had a hard time hitting 25, later around 80 all this without there being more devices connected and without any additional networks in the area that might crowd up airspace.
Let me know if you need any more details.
Thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok as long as the ISP modem is in bridge mode you'll be fine there.
What are the wired LAN cable speeds with a PC?
What wireless devices are you using to speed test?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problems recently. My main network crawls over wireless (<1Mbps) but if I switch to the guest network it is >35Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to add a little more. I have updated the router to the latest firmware as of this posting (2.3.1.60) and the problem still exists after the update. The performance difference is seen from the same machine at the same location in my house, I'm just switching from my main orbi wireless to the guest network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed yet since the update?
