Orbi WiFi 7 RBE973
Reply
Orbi Max Speed Lan
jamination
Orbi Max Speed Lan
Recenlty I upgraded my internet from 240 download (static ip) to 640 dynamic ip.  I changed the router to dynamic ip and the LAN speed tests were coming in far short (about 180), however the orbi speedtests were consistently 480 give or take .  After a lot of fiddling around I eventually turned off Armor and that basically (on a Lan computer) got me to the 480.  This is obviously far better however I am wondering if there could be anything holding me back from getting the full 600+, again I am talking about LAN only.  I know it is coming in the house at 600 as the installation guy showed me and I also tested it directly into a computer myself.
thanks
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
interestedperso
Re: Orbi Max Speed Lan
Interesting Subject, i also also am struggling with anything over 480mb on a 500mb plus connection.
I am hoping this can be resolved as anything up to 1gb should be viable i suspect.
Message 2 of 5
Guru
@interestedperso @jamination
FYI:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/m-p/...
@Blanca_O
Message 3 of 5
jamination
The modem is an Arris Touchstone TG2472.
Phil
Message 4 of 5
Guru
You have a gateway modem/router unit. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Phil
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1035 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
