- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Mini RBK22: Issue with 5G and 2.4G connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have the Orbi Mini RBK22 which include one satellite router. When I connect with my sercurity CAM, which need 2.4G connection, then my other devices (mobile, tablet) will lose video streaming capability even they are still showed connected.
Checked some Q&As here, I am wondering if it has changed all my connections to 2.4G but not 5G.
Q1: what's the problem of such issue?
Q2: should I follow the instruction to set different SSID for 2.4G and 5G? How should I set it up by using the APP? or should I connect with a laptop?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Mini RBK22: Issue with 5G and 2.4G connection
Hi,
It sounds like your secuirty CAM is connecting to 2.4Ghz using an old WiFi protocol I.e.802.11b, which I believe will cause all your other devices connected to 2.4Ghz to also use 802.11b, which will reduce available bandwidth.
If you split your 2.4Ghz and 5Ghz to different SSIDs then as long as your other devices can connect to the 5Ghz you should be all set to go?
Good luck 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there anyway to make the SSID change via APP? Or it has to be done via laptop?
I have tried to connect my camera to guest WiFi, which I learnt from another related post, while it didn’t work for me.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Fl1ntstone wrote:It sounds like your secuirty CAM is connecting to 2.4Ghz using an old WiFi protocol I.e.802.11b, which I believe will cause all your other devices connected to 2.4Ghz to also use 802.11b, which will reduce available bandwidth. (yes, reduces bandwidth on the 2.4G channel. Does NOT affect the 5G channel)
I do not see the need to create a different SSID for 5G devices. If they already can connect at 5G, then most of them should connect at 5G. Mine certainly do, and I have only the standard "one Orbi SSID".
Unless this is a horribly expensive security camera, my first choice would be to get one with more modern WiFi capabilities. The 1080p Wyze cam was under $30 including tax and shipping and it supports 802.11b/g/n.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can temporarily disable the 5ghz SSID by unchecking the Enable SSID Broadcast under Advanced Tab/Advanced Settings/Wireless Settings. This willl force all connections to the 2.4Ghz radio. See what this does for you.
@Argassi wrote:
Thank you.
Thank you.
