Reply
Orbi No internet
Hallc234
Orbi No internet
Woke up today to no internet!
Called Xfinity and they confirmed cable modem is getting signal and passing it thru ethernet cable to the orbi router. 3 backhaul wires from router to satelites are not working and wireless from router is not working.
Model: RBK43| Orbi AC2200 WiFi System
Message 1 of 8
DarrenM
Sr. NETGEAR Moderator
Re: Orbi No internet
Have you tried to power cycle the modem and all of your orbi units could be some type of Ip conflict happening.
DarrenM
Message 2 of 8
Guru
What Mfr and model# modem do you have? Any built in router here by chance?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 3 of 8
Hallc234
I had installed with router using wire connections to 2 satellites and then wireless from satellites to items. I had to disconnect the wires from router to satellites and reboot and then it worked. But when I plugged back in the wires it failed again. I am now running totally wireless but am finding I have to keep rebooting the router because it randomly just stops working.
Message 4 of 8
Jgobble
Tutor
This is what I am going through..
Almost daily reboots of the router unit. That (sometimes) doesn't fix it ... and I must reboot the SB6183 modem (via XFinity)...then reboot the router. Then it comes up.
The entire time this happens I can get to my hardwired mac mini from my wireless devices...just not the internet...by IP or by domain name.
FIX THIS!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 5 of 8
Guru
Try a factory reset on both router and satellite and set up from scratch.
FIX THIS!
Message 6 of 8
Jgobble
Tutor
This would be a good idea if I had not gone through almost an hour of entering all my MACADDR->STATIC IP mappings and done port forwarding changes too...
Do you mean do a factory reset and then re-upload my saved settings? Otherwise I just can’t see doing this...every time the orbi fails.
Message 7 of 8
Guru
Just to see if from scratch fixes anything, then if so, try too apply a saved configuration from file.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3818 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
