- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Playstation Network Connection Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow! I spent the last 6 hours trying to figure out why my Orbi Mesh Wifi system wasn't connecting to PSN on my playstation 3 counsle. Watch this video ( https://www.youtube.com/watch?v=Sv3N3eNqOV4 ) and try manually entering the DNS server on the ps3 to either 8.8.8.4. (Primary) / 8.8.4.4. (secondary) OR the 1.1.1.1. /1.0.0.1. did the trick! All i did was enter it during wifi set up and then sign out of PSN and sign in again. Note that during "test connection" it will still say "failed" under PSN. Disregard that, sign out of PSN and then sign back in. Should do the trick!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Playstation Network Connection Issue
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Buit in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
