Orbi WiFi 7 RBE973
Reply
Orbi Pro vs Orbi Voice (RBS40V) - work together in an orbi system (not expander)
div_online_UA
Follower
For several days I’ve been trying to configure the possibility of joint work of Orbi Pro SRR60 vs Orvie Voice RBS40V in an Orbi system (not like a Wi Fi-extender by cable from the main router).
According to the NetGear, this satellite, RBS40V - model, should work with ANY Orby system ...
Someone did it, or just as a Wi Fi network extender?
Model: SRK60B03|Orbi Pro Tri-Band Business WiFi System
Message 1 of 3
Blanca_O
NETGEAR Moderator
Re: Orbi Pro vs Orbi Voice (RBS40V) - work together in an orbi system (not expander)
Hi @div_online_UA
Welcome to NETGEAR Community!
Orbi Voice satellite (RBS40V) in Orbi Mode can be paired with Orbi Home routers such as RBR50, RBR40, RBR20, CBR40...
For you to sync the Orbi Voice Satellite (RBS40V) to your Obri Pro System then Satellite should be setup in Extender mode. Here's a reference of how to set it up in Extender mode: https://kb.netgear.com/000061427/
Blanca
Community Team
Message 2 of 3
SLO5OH
So let me get this straight... In able to use a RBS40V with the SRR60 you have to put the RBS40V in Extender mode, rendering the Alexa features virtually useless because you are unable to access it as a Satellite in the Orbi app on your phone. Am I correct?
Model: RBS40V|Orbi Voice Add-on WiFi Satellite and Smart Speaker
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 949 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
