- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RB40 keeps blocking certain devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
RB40 with two satellites (RB20) seems to have a hard time staying connected to specific devices, even with the satellite next to the device. The system "Blocks" acess often and when I try and change in Access Controls, it wont switch to Allow.
Been getting worse and worse since early 2020
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RB40 keeps blocking certain devices
