- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RB50 Satellite Status LEDs activity
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently my Orbi RB50 satellite's status lights have been more "active" than in the past, the the base station and satellite have not changed position. Several times a day the satellite will cycle from amber to blue. Sometimes, just the blue LED comes on, and other times just the Amber. My internet speed seems consistent using the smart phone speed test.
I understand what the colors "mean" but don't know whether or not to be concerned about the higher rate of LED activity?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
That would indicate the satellite and router have a poor connection. I would move one or both so they are closer together and/or have fewer building materials between. Also, make sure neither unit is near another source of radio frequency interference. That could include Bluetooth devices, wireless speakers, etc. This probably started with the recent firmware update to 0.74
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RB50 Satellite Status LEDs activity
Thanks for the quick reply. I'll adjust the postion of my satellite Orbi and see if that reduced the cycling of the LEDs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RB50 Satellite Status LED activity followup questions
I've moved my Orbi satellite to a new location and I no longer get the amber LED, but every so often, the blue LED comes on. Is that a function of the software update you wrote about? Is the satellite automatically checking its status?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you have improvement. That's good to hear.
The blue light probably means the satellite is falling back to a 2.4 GHz backhaul connection. You must still have some mild connectivity issues. Maybe you have a lot of RF interference in the home. Or the satellite and router are still too far apart.
I'm not sure about the radiation pattern, but I don't think it matters much. The Orbi uses multiple antennas and beamforming, so it can change the pattern.
I would think shelf mouting would be fine. Against the wall should be OK. Higher up is usually better for WiFi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again for answering my followup questions. My wi-fi signal strength measures are the same, and Ookla speed test results are now almost exactly the same between the base station and satellite "zones" of my apartment. The Orbi continues to live up to its reputation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds good. My Orbi has been solid for 10 months and working great too.
