Orbi WiFi 7 RBE973
Reply
Orbi RBK 50 AC3000
HoangNa297
Orbi RBK 50 AC3000
I'm just Update new version newest form orbi app ( V2.1.4.10) is problem,it's drop my connection .. i want to get back old firmware ...any help me downgrade ??? thanks..sorry my bad english 😞 !
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 6
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Orbi RBK 50 AC3000
You could try a factory reset it has had good results for others after upgrading to this firmware.
DarenM
Message 6 of 6
All Replies
Guru
Has a system reboot or a full factory reset then set up from scratch been performed?
Message 2 of 6
HoangNa297
It’s only auto reboot when update finish,i’m don’t hard reset it,i’t seem this firmware not stable
Message 3 of 6
DarrenM
Is all of your orbi units upgraded to the 2.1.4?
DarrenM
Message 4 of 6
HoangNa297
Yes,i have check it on my computer,both router and satellite run firmware 2.1.4.10,i’m should reset factory ?
Message 5 of 6
DarrenM
DarenM
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1605 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
