Orbi WiFi 7 RBE973
Reply
Orbi RBK23 AC2200- Need a solution for added ethernet ports at modem
rider311
I have the RBK23 router with 2 satellites.  My issue is that I need additional ethernet ports at the router.  This model only has one ethernet port.  Is there a device I could add to increase the quantity of ethernet ports between the modem and the router?
Thanks
Message 1 of 6
Mstrbig
Master
Re: Orbi RBK23 AC2200- Need a solution for added ethernet ports at modem
Thanks
I would add a Netgear ProSafe Gigabit switch, plug it into the Lan port of the router and you can connect Orbi satellites as well as other devices. The switch comes in various sizes and they are very cost effective.
Message 2 of 6
Guru
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Thanks
Message 3 of 6
rider311
Thanks for the suggestion, it works great.
Message 4 of 6
Guru
Enjoy, Smiley Wink
Message 5 of 6
Mstrbig
Master
Glad it worked out.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 801 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
