Orbi WiFi 7 RBE973
Reply
Orbi RBK30, flashing white all the time
Taeba
So after a power outage our Orbi continuously flashes white, I have power cycled it. No change, I have tried syncing , no change....went to factory reset the main unit and it won't go amber colour, the satellite will but not the base unit.  This was working great until the power outage, we have only had it a few weeks. And now I'm thinking we own an expensive paper weight.  Can anyone help with some suggestions, bearing in mind I'm not that tech minded lol.
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Orbi RBK30, flashing white all the time
Hello Taeba
we have identified this as a issue with the RBK40/30 units and you will need to contact support they will be able to help with this issue
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 3
Taeba
Hi Darren M,
Thanks foir the reply.
I have contacted Netgear, and they have had me run ping tests etc, and it looks like I have a defective Orbi, so they are going to replace my system.
Taeba
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3289 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
