- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK30
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBK30
Please advise
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK30
Is the Orbi system operating in Router or AP mode?
Built in router already at the modem by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure to walk thru the setup wizard with a wire connected PC at the RBR...
