Reply
Orbi RBK40 & RBS50Y Compatibility
rakserv
I have an Apple Airport Time Capsule that provide good coverage for most of my house, there are a few dead zones that I have wired ethernet (1GbE) close to and i also have low signal and throughput in my backyard.  I really have two objectives;
  1. I would like to run an Orbi in Access Point Mode to provide coverage to the dead spots -AND-
  2. I would like to improve the wireless signal in my backyard.
I wanted to know if i could:
  1. Use the RBK40 - AC2200 to provide an access point for my existing apple time capsule network using ethernet backhaul -AND-
  2. If needed use the RBS50Y - Outdoor Satellite with the RBK40 routher
thank you,
Model: RBK40| Orbi AC2200 WiFi System, RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 4
Guru
Re: Orbi RBK40 & RBS50Y Compatibility
You'll need to check with Apple to see if the Time capsule can be configured using LAN cableing. If it has a RJ45 LAN port, then I presume so.
The RBS50Y will connect to the RBR40 router for out door wifi support.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX800 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 4
rakserv
thank you for the information.
the apple time capsule does in fact have 1GbE RJ45 ethernet ports.
Message 3 of 4
Guru
I would run the Orbi wifi only and not use the Apple wifi. This could cause additional interferences...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 759 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
