- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK50-100PES
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBK50-100PES
Guten Tag
ich betreibe ein Orbi RBK50-100PES und 3 RBS50 Satellit.
Gibt es eine möglichkeit W-Lan Geräte von einem Satelit auf den anderen zu verschieben?
Ich habe W-Lan Geräte welche sich, obwohl, direkt neben einem RBS50 Satellit stehen,
immer auf den viel entfernteren Router RBK50-100PES verbinden.
Besten Dank
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK50-100PES
Is there a way to move Wi-Fi devices from one satellite to another?
I have Wi-Fi devices which, though, are right next to an RBS50 satellite,
always connect to the much farther router RBK50-100PES.
Thank you very much
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is Fast Roaming and Daisy Chain enabled or disabled?
Most devices handle there own connection to the Orbi and they connect to what signal is best for them. Not way to make them connect to a certain signal.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
