- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK50 Ac3000 repeater connection/repeating via ethernet instead of wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am looking to buy a router and repeater that can be used to send a signal through the house using CAT6 Ethernet, while also adding a repeater for the second floor for Wi-Fi devices, which is separated from the ground floor by a concrete slab. My concern is that if the Orbi can only repeat a signal using Wi-Fi, the concrete may inhibit the signal from reaching the repeater as the walls are also brick (The house is 3300 sq ft in total). Can anyone please advise if the Orbi rbk50 ac3000 can repeat a signal from an Ethernet port instead of via Wi-Fi and whether this particular router/repeater combi is the best option for my situation.? I know that there was already a discussion on this in 2016, but as some time has past i was hoping that things may have changed since. Thank you for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi RBK50 Ac3000 repeater connection/repeating via ethernet instead of wifi
Orbi systems can use a ethernet connection between the Orbi router and Orbi Satellite for wired back haul connection. Thus the satellite becomes a wired AP for remote locations for wireless AP access and transferring traffic on the ethernet back haul connection.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK853 (Router Mode), Wired Backhaul and R8000 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
