- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK50 - Need help to setup with Singtel
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I have just bought the Orbi RBK50 recently. However, I have difficulties setting up the router with my Singtel ONT. Are there any settings I need to change in order for me to connect the Singtel ONT to the router (ie. RBK50)? If yes, what are the settings I need to change?
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK50 - Need help to setup with Singtel
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too? Built in router here by chance?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Any specific ISP account configurations, you'll need to talk to your ISP about this to get there help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. Thanks for your advice. My model of my ONT is as below link and is not a built in router.
https://www.singtel.com/personal/support/broadband/routers-ont/zte-ont-led-troubleshoot
I have tried various methods including setting up the VLAN tag group https://kb.netgear.com/000038854/How-do-I-set-up-a-bridge-for-a-VLAN-tag-group-for-my-Orbi-WiFi-Syst... but it still cannot connect to internet. Not sure of the reasons. I tried calling my ISP and they indicated that the ONT is working and that they are unable to help much. They told me that the issues and settings lie with the Orbi router and not from their side.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does connecting a PC directly to the ONT work or do you have to make some special configurations on the PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
