Orbi WiFi 7 RBE973
Reply
Orbi RBK50 Slow Upload speeds
Manny67000
Follower
I had an orbi rbk50 system for almost a year and a half with absolutly no issues. After the latest firmware update my upload speeds went from 36 to 2.5 which is unacceptable. I disconnected the router and plugged my laptop directly to the moden to eliminate a faulty modem from the equation. I'm getting full speeds at the modem. Once I connect my laptop to the router after plugging it back in it drops back down to 2.5. Now I still have the warrenty I bought from best buy and was able to swap it out for a new one. it was working well for 1 week and then the exact same issue arose on the new one. Has anyone else had this issue? If so does anyone have a fix for it? Otherwise I will be bringing this one back and swapping it out for an eero system.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi RBK50 Slow Upload speeds
Has a factory reset and setup from scratch with the RBR been performed since the FW update?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 636 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
